Fan Tray 2 cannot be seen on the "show environment all"
Oct 25th, 2009
Hi there,
We have a 6509 chassis with CatOS 8.5(1) and WS-X6K-SUP2-2GE supervisor engine. We want to upgrade with IOS so we replaced the fan tray and power supplies. After the replacement, the two power supplies went okay based on their status in the captured logs. Unfortunately, we have replaced the WS-C6K-9SLOT-FAN with WS-C6K-9SLOT-FAN2= but it was not seen on the show environment all. Also, based on the show inventory, the installed fan tray is still the old one, and it is written with Fan Tray 1 (not with Fan Tray 2), hence the status is OK. We've already reseated but results are still the same.
We need a little help in here. Thanks! =)
Leo Laohoo Sun, 10/25/2009 - 22:21
Is your P/S the 2500 W or 4000 W power supply?
What's the status light of the fan?
shennacacao Sun, 10/25/2009 - 23:26
Those are both 3000 W power supplies, and the status light of the fan is green which means okay/normal. Thanks!
