Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929247members
1243462discussions
Community Activity
AP2702i degrading throughput
Hi community!I posted about some 2702i in autonomous mode, degrading throughput after some time - see post: Autonomous Mode Failing on Aironet 2702i-z-k9 - Cisco CommunityLast days I got a WLC 2504 and other 2702i access points  (in controlled - LWAP...
AP issue
Hello we have a local 9120axi AP with a 9800LC WLC that seems to be losing connection. The AP is in flex connect, all config looks fine: AdvancedCountry CodeUS  Multiple CountriesUSStatistics Timer180CAPWAP MTU1485AP Link LatencyEnabledAP PMK Propaga...
8851 Kem
Dear Sir i am new to 8851 ip phone , just need help for speed dial kem i do program speed dial entries into the device and when the phone is turned off the entries are lost is there is any advice why list is forgotten from the phone ? thanks
heamer by Level 1
  • 121 Views
  • 3 replies
Call Handler Not Reachable From Outside Call
Hi Experts,I am sitting with an unique issue where my Auto Attendant works perfectly from inside the office, however it is not reachable from external calls.Connection ISP > SIP > CUBE > SIP > CUCMWhat I am seeing is as soon as I direct the call to C...
Resolved! Configuring NAT overload with vrf lite on a CAT9K
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12.  This is what I am struggling with, I currently have a vrf called AWSDX-S3.  Now what I am trying to do is I have added a L2 SW and ran trunk ports...
gurowar by Level 1
  • 357 Views
  • 16 replies
switching
hello every body what is the differentsfp-10/25g-lr-s (10-3251-01) and sfp-10/25g-lr-s (10-3251-02)
nagy by Level 1
  • 3 Views
  • 1 replies
Cisco CM Switch Box
Our Forum Alert III Secondary Crash Net (SCN) is inoperable. I've heard the cisco cm could be configured to set up some devices to act as a ringdown, they called it a “Switch Box.” This would allow our Base Operations guys to have a work around from ...
Cisco SD-WAN prefix list & data prefix list update
Wanted to understand the best practices when updating the prefix-list & data prefix list in SD-WAN network.For example I have the below prefix-listlist_abc: 10.10.10.0/24This prefix list has been used in Centralized policy.I wanted to added new subne...
RS19 by Level 4
  • 100 Views
  • 4 replies
How to copy Cisco C9300L IOS and Bootstrap to USB drive
I accidentally bricked my Cisco C9300L switch and no longer has IOS or Bootstrap.   Can I save copy of IOS and Bootstrap from my  other Cisco C9300L switch and save to USB drive?  Then copy images onto the switch that is inoperable?
