VPN-tunnel redundancy
Oct 26th, 2009
There is two site with 2801/CallManager Express routers. I need to have LAN-2-LAN connection over Eth WAN interfaces.
It is possible to configure two VPN tunnel with redundancy? How to monitor VPN-tunnel state and switch to second tunnel?
Jody Lemoine Thu, 10/29/2009 - 11:48
  • Gold, 750 points or more
  • Community Spotlight Award,
    Member's Choice, April 2016
There are a number of ways to go about it, but I would run with two encrypted tunnels and a routing protocol such as EIGRP to balance or provide failover. Something like this would do the trick.
! Router 1
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
crypto isakmp key ***** address 3.3.3.2 no-xauth
crypto isakmp key ***** address 4.4.4.2 no-xauth
crypto ipsec transform-set TS-AES256SHA1ESP esp-aes 256 esp-sha-hmac
crypto ipsec profile VPN
set transform-set TS-AES256SHA1ESP
interface FastEthernet0/0
ip address 1.1.1.2 255.255.255.0
interface FastEthernet0/1
ip address 2.2.2.2 255.255.255.0
interface Loopback0
ip address 10.0.0.1 255.255.255.0
interface Tunnel0
ip unnumbered Loopback0
tunnel source FastEthernet0/0
tunnel destination 3.3.3.2
tunnel mode ipsec ipv4
tunnel protection ipsec profile VPN
interface Tunnel1
tunnel source FastEthernet0/1
tunnel destination 4.4.4.2
router eigrp 10
network 10.0.1.0 0.0.0.255
ip route 1.1.1.0 255.255.255.0 3.3.3.1
ip route 2.2.2.0 255.255.255.0 4.4.4.1
! Router 2
encr aes 256
group 2
crypto isakmp key ***** address 1.1.1.2 no-xauth
crypto isakmp key ***** address 2.2.2.2 no-xauth
ip address 3.3.3.2 255.255.255.0
ip address 4.4.4.2 255.255.255.0
interface Loopback0
ip address 10.0.1.1 255.255.255.0
interface Tunnel0
tunnel destination 1.1.1.2
interface Tunnel1
tunnel destination 2.2.2.2
router eigrp 10
You'll want to make substitutions as follows:
***** - Your tunnel keys
Loopback0 - LAN Interface for each router
10.0.0.0 - LAN Subnet for Router1
10.0.1.0 - LAN Subnet for Router2
1.1.1.0 - WAN Subnet for Router1 FastEthernet0/0
1.1.1.1 - Next-hop Router for Router1 FastEthernet0/0
1.1.1.2 - Interface of Router1 FastEthernet0/0
1.1.1.0 - WAN Subnet for Router1 FastEthernet0/1
1.1.1.1 - Next-hop Router for Router1 FastEthernet0/1
1.1.1.2 - Interface of Router1 FastEthernet0/1
3.3.3.0 - WAN Subnet for Router2 FastEthernet0/0
3.3.3.1 - Next-hop Router for Router2 FastEthernet0/0
3.3.3.2 - Interface of Router2 FastEthernet0/0
4.4.4.0 - WAN Subnet for Router2 FastEthernet0/1
4.4.4.1 - Next-hop Router for Router2 FastEthernet0/1
4.4.4.2 - Interface of Router2 FastEthernet0/1
You'll also want to adjust subnet masks and routing wildcards appropriately for your actual subnet masks.
This will create two VPN tunnels, each using a separate Internet connection on the FastEthernet ports. The EIGRP routing protocol will balance between them, using a single tunnel only when one should fail.
You can track which are up by monitoring the tunnel interface status.
