E1 over 5ess switch type.
Answered Question
Oct 26th, 2009
Is it possible to use a E1 over 5ess (5ess) isdn switch type ?
And if is possible, somebody have some ideia to do that ?
Ab
Correct Answer by Paolo Bevilacqua about 7 years 5 months ago
Under controller E1, configure clock source internal.
Under serial interface, isdn protocol-emulate network.
Please remember to rate useful posts with the scrollbox below.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Mon, 10/26/2009 - 03:16
  • Hall of Fame,
    Founding Member
It is possible, what exact problem are you trying to solve ?
Antonio Brandao Mon, 10/26/2009 - 03:25
I'm connecting my 2811 router with a Nortel PBX using a E1 connection and my D channel isn't getting up. see outputs bellow
sh conf
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-5ess
isdn gateway-max-interworking
controller E1 0/0/0
pri-group timeslots 1-2,16
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn send-alerting
no cdp enable
gw-jlplda-0#sh isdn status
Global ISDN Switchtype = primary-5ess
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-5ess
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Number of L2 Discards = 0, L2 Session ID = 47
Total Allocated ISDN CCBs = 0
sh debug
gw-jlplda-0(config-controller)#
001891: *Oct 26 10:25:43: %CONTROLLER-5-UPDOWN: Controller E1 0/0/0, changed state to up
001892: *Oct 26 10:25:45: %LINK-3-UPDOWN: Interface Serial0/0/0:15, changed state to up
001893: *Oct 26 10:25:47: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
001894: *Oct 26 10:25:48: %MARS_NETCLK-3-HOLDOVER: Exiting Holdover for Controller E1 0/0/0
001895: *Oct 26 10:25:56: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
001896: *Oct 26 10:26:05: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
gw-jlplda-0(config-controller)#BAD FRAME()
001897: *Oct 26 10:26:14: ISDN Se0/0/0:15 Q931: Ux_DLRelInd: DL_REL_IND received from L2
Correct Answer
Paolo Bevilacqua Mon, 10/26/2009 - 03:31
  • Hall of Fame,
    Founding Member
