do 7815I2 support upgrade to 7.1
Oct 26th, 2009
please light me 7815I2 will support 7.1 upgrade
Overall Rating: 5 (1 ratings)
rob.huffman Mon, 10/26/2009 - 05:25
Hi Bala,
Yes, the 7815I2 is supported for this upgrade path :)
This is the "master" list for Server support;
Supported Cisco Unified Communications Manager Releases by Server
**Supported, but note that Cisco Unified Communications Manager 6.1 and higher requires original CPU > 2GHz, memory of minimum 2GB for MCS 7815/16/25/35, 6GB for MCS 7828 and 4GB for MCS 7845, and hard drive capacity of 72/80 GB or higher. This will result in mandatory memory and hard drive upgrades if older supported servers are desired for use with the new software versions.
Hope this helps!
BALAMURUGAN SINGARAM Mon, 10/26/2009 - 05:35
Thanks Rob, 7815I2 server coming with 2GHZ and 2GB ram with 72 GB HDD. With this configuration can I upgrade from cucm 5.1 to 7.1, please light me Rob
rob.huffman Mon, 10/26/2009 - 05:45
Hi Bala,
You are most welcome my friend! Yes, it looks like you would be "good to go"
skravens0929 Mon, 10/26/2009 - 12:59
If I max out my 7816 with maximum ram and the extra I still limited to 500 devices?
