Call Logging on Call Manager 6
Answered Question
Oct 26th, 2009
Is there an easy way to produce an report on CM that will show all incoming and outgoing calls made and to what ext the call came from or call to?
TIA
John
Correct Answer by James Hawkins about 7 years 6 months ago
CallManager includes a basic call accounting system called the CAR (CDR Analysis and Reporting) tool.
You did not specify your CCM version so I have provided a link to the 7.1 admin guide below.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/CAR.html
Note that CDR records are not enabled by default - you need to enable them as described in the document.
Overall Rating: 5 (1 ratings)
Correct Answer
James Hawkins Mon, 10/26/2009 - 06:41
  • Gold, 750 points or more
SuperGenius Mon, 10/26/2009 - 09:19
Thanks, that was it. It was turned on by the local phone company when they installed the system... We just didn't know about it.
John
