IOS, "management-access inside" command available?
Oct 26th, 2009
"management-access inside" command is available in ASA/PIX to access inside interface via VPN client.
Is a similar command available in IOS?
Thanks in advance,
JORGE RODRIGUEZ Mon, 10/26/2009 - 11:51
  • Green, 3000 points or more
As far as I know there is no equivalent command in IOS as asa/pix management-access , you can still allow management access to the router, use acls ssh or telnet allowing vpn RA network and apply to vty lines. Perhaps use local user database for ssh/telnet access auth if you want to be more granular on which RA users can administer router through vpn.
