CRS Historical Reports OLD Skills/Group
ipereira Wed, 10/28/2009 - 13:52
I have the same problem here.
I try to find here HR save this, but I could not find.
Jonathan Schulenberg Wed, 10/28/2009 - 18:56
  • Cisco Designated VIP,
    2017 IP Telephony
Did you rename an existing skill or add new ones?
Deleted values from the UI are retained in the db_cra database. Deleting them would destroy the historical reporting database and make report generation from the timeline they were in use impossible.
I rename, delete and create new one.
So they will stay there for ever? Because I dont need reports older than 1 month ago. Because I have 70 schedules reports thats run every week and month saved on my servers
Another question I have, any way to change the name for a custom name in the scheduler? Because I run 5 reports, for 7 groups each weeks and months but in the Scheduler they all look the same. So every time I have to do change I need to delete all that have the same name and redo them.
