Blocking users using mac address
Oct 26th, 2009
I have some users on our corporate network who I need to block from the network using mac address. I can't do this via dhcp because the users are using static IPs which they keep changing once it is blocked on the PIX 515E using the shun command.
How can I block access to these users on the PIX. The PIX is the default gateway.
prince.ibe Mon, 10/26/2009 - 12:41
I have a slightly complex situation at the moment which I hope to solve in the near future.
I inherited a flat network. No VLANs. No DMZ. In fact, the PIX acts as the LAN gateway with only 2 ports - one inside the other outside to a router which connects to the internet via vsat modem.
I hope to implement some control soonest using websence but before then, I am up to my chin troubled about this particular user that frequently changes his static IP and throttles the network badly.
What other method can I readily deploy to cut him permanently off the network? ...
