Juniper (dynamic IP) to PIX (Static IP) VPN
Oct 26th, 2009
We require assistance in configuring site2site vpn (Juniper-NS5GT-ADSL-WLAN in a branch office with ADSL connection (dynamic IP) and the pix 515e OS version 8.0 in the head office with a fixed IP
Patrick0711 Mon, 10/26/2009 - 08:06
  • Bronze, 100 points or more
The Juniper device with the dynamic IP will always have to initiate the IKE negotiation.
You will configure a normal static site-to-site from the Juniper to PIX.
On the PIX, you'll use NAT-exempt access-lists, a dynamic crypto-map, and the DefaultL2L group.
The PIX Configuration would reference the 'Lion' peer in the following example.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805733df.shtml
aalsaadi1 Tue, 10/27/2009 - 07:08
Thanks Patrick
We tried the above scenario but still unfortunately getting errors
Below id the PIX configuration:
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 3
encryption 3des
hash md5
group 2
lifetime 28800
crypto isakmp policy 4
encryption des
hash sha
group 2
lifetime 28800
crypto isakmp policy 5
encryption des
hash md5
group 2
lifetime 28800
crypto isakmp policy 6
encryption aes
hash md5
group 2
lifetime 28800
crypto ipsec transform-set JuniperInDXBset esp-3des esp-md5-hmac
ccess-list NoNat line 5 extended permit ip 10.200.2.0 255.255.255.0 10.200.13.0
255.255.255.0
nat (inside) 0 access-list NoNat
crypto dynamic-map JuniperInDXBMap 1 match address juniper
crypto dynamic-map JuniperInDXBMap 1 set pfs
crypto dynamic-map JuniperInDXBMap 1 set transform-set JuniperInDXBset
crypto dynamic-map JuniperInDXBMap 1 set security-association lifetime seconds 3
600
crypto dynamic-map JuniperInDXBMap 1 set reverse-route
crypto map AirarabiaMAP 3 ipsec-isakmp dynamic JuniperInDXBMap
crypto map AirarabiaMAP interface outside
Patrick0711 Tue, 10/27/2009 - 12:12
You do not need the following:
'crypto dynamic-map JuniperInDXBMap 1 match address juniper'
The NAT exempt access-list will govern dynamic tunnel's encryption domain.
Are you running OSPF on the device? If not, you don't really need the following:
crypto dynamic-map JuniperInDXBMap 1 set reverse-route.
Please also ensure that the pre-shared key is configured in the DefaultL2LGroup on the PIX.
aalsaadi1 Wed, 10/28/2009 - 01:13
Hi Patrick
removing the above message didnot work. I suspect the Juniper config below is causing the problem
set interface trust ip 10.200.13.1/24
set interface trust nat
set interface wireless2 ip 192.168.2.1/24
set interface wireless2 route
set interface adsl1 ip 217.165.237.86/32
set interface adsl1 route
set interface tunnel.1 ip unnumbered interface trust
set interface wireless1 mtu 1500
set interface tunnel.1 mtu 1500
unset interface vlan1 bypass-others-ipsec
unset interface vlan1 bypass-non-ip
set interface trust ip manageable
set interface wireless2 ip manageable
set interface adsl1 ip manageable
set interface trust dhcp server service
set interface wireless2 dhcp server service
set interface trust dhcp server auto
set interface wireless2 dhcp server auto
set interface trust dhcp server option gateway 192.168.1.1
set interface trust dhcp server option netmask 255.255.255.0
set interface wireless2 dhcp server option gateway 192.168.2.1
set interface wireless2 dhcp server option netmask 255.255.255.0
set interface trust dhcp server ip 192.168.1.33 to 192.168.1.126
set interface wireless2 dhcp server ip 192.168.2.33 to 192.168.2.126
set flow tcp-mss
unset flow no-tcp-seq-check
set flow tcp-syn-check
set hostname ns5gt-adsl-wlan
set pki authority default scep mode "auto"
set pki x509 default cert-path partial
set address Trust "10.200.13.0/24" 10.200.13.0 255.255.255.0
set address Untrust "10.200.2.0/24" 10.200.2.0 255.255.255.0
set ike p1-proposal "pre-g2-3des-sha-43200" preshare group2 esp 3des sha-1 second 43200
set ike gateway "Airarabia Firewall" address a.b.c.d Aggr outgoing-interface "adsl1" preshare "r1yj20rrN7C2YNstgUCrUDUDBZnGj8ktHw==" proposal "pre-g2-3des-sha"
set ike gateway "Airarabia Firewall" cert peer-ca all
set ike gateway "Airarabia Firewall" nat-traversal
unset ike gateway "Airarabia Firewall" nat-traversal udp-checksum
set ike gateway "Airarabia Firewall" nat-traversal keepalive-frequency 0
set ike respond-bad-spi 1
unset ipsec access-session enable
set ipsec access-session maximum 5000
set ipsec access-session upper-threshold 0
set ipsec access-session lower-threshold 0
set ipsec access-session dead-p2-sa-timeout 0
unset ipsec access-session log-error
unset ipsec access-session info-exch-connected
unset ipsec access-session use-error-log
set vpn "VPN-to-Airarabia HO" gateway "Airarabia Firewall" no-replay tunnel idletime 0 proposal "g2-esp-3des-md5" "g2-esp-3des-sha"
set vpn "VPN-to-Airarabia HO" monitor optimized
set vpn "VPN-to-Airarabia HO" id 1 bind interface tunnel.1
set url protocol sc-cpa
set vpn "VPN-to-HO" proxy-id local-ip 10.200.13.0/24 remote-ip 10.200.2.0/24 "ANY"
set policy id 2 name "out-in" from "Untrust" to "Trust" "10.200.2.0/24" "10.200.13.0/24" "ANY" permit log
set policy id 2
set policy id 1 name "in-out" from "Trust" to "Untrust" "10.200.13.0/24" "10.200.2.0/24" "ANY" permit log
set policy id 1
set pppoa name "ADSL connection to Etisalat" username "abs05" password "iMSM+w8MNLOkWEsvqnCqZ8mDP+no0qEOgQ=="
set pppoa name "ADSL connection to Etisalat" interface adsl1
unset pppoa name "ADSL connection to Etisalat" update-dhcpserver
set global-pro policy-manager primary outgoing-interface adsl1
set global-pro policy-manager secondary outgoing-interface adsl1
set nsmgmt bulkcli reboot-timeout 60
set ssh version v2
set config lock timeout 5
set modem speed 115200
set modem retry 3
set modem interval 10
set modem idle-time 10
set wlan country-code AE
set wlan channel auto
set ssid name Netscreen
set ssid Netscreen authentication wpa-psk passphrase r8aEjJpANhtt7rsR8YCMyAdWD/n+xk/Y2A== encryption auto
set ssid Netscreen interface wireless2
set snmp port listen 161
set snmp port trap 162
set vrouter "untrust-vr"
set vrouter "trust-vr"
unset add-default-route
set route 10.200.0.0/16 interface tunnel.1 preference 20
aalsaadi1 Thu, 10/29/2009 - 06:42
Hello Patrick,
Actually I managed to get the Tunnel up, it was a mis configuration from both side, however after the tunnel is up still I'm not able to pass traffic between both sites.
Appreciate your help on below configuration:
PIX IOS 8.0(2) Config:
access-list NoNat extended permit ip 10.200.2.0 255.255.255.0 10.200.13.0 255.255.255.0
crypto ipsec transform-set JuniperInDXBset esp-des esp-sha-hmac
crypto dynamic-map JuniperInDXBMap 1 set security-association lifetime seconds 3600
encryption des
hash sha
group 2
lifetime 28800
******tunnel-group DefaultL2LGroup ipsec-attributes********
pre-shared-key 12345
Juniper 5GT config:
set ike gateway "AirarabiaFirewall" address a.b.c.d ****main***** outgoing-interface "adsl1" preshare "12345" proposal "pre-g2-des-sha"
set vpn "AirarabiaVPN" gateway "AirarabiaFirewall" no-replay tunnel idletime 0 proposal "nopfs-esp-des-sha" "nopfs-esp-3des-md5" "nopfs-esp-3des-md5"
set interface "tunnel.1" zone "Trust"
set interface tunnel.1 ip unnumbered interface adsl1
set vpn "AirarabiaVPN" bind interface tunnel.1
set vpn "AirarabiaVPN" proxy-id local-ip 10.200.13.0/24 remote-ip 10.200.2.0/24 "ANY"
set route 10.200.2.0/24 interface tunnel.1
****indicates the change I've done to make work.
