How to downgrade a device pack
Answered Question
Oct 26th, 2009
Hello I installed the latest device pack in a callmanager 5.1 cluster. I am having problems with the ip phone getting the new firmware ("tftp auth fail") and I wish to install a device pack older than that; How can I make a downgrade of the device pack?
Correct Answer by Jaime Valencia about 7 years 8 months ago
There is no downgrade or uninstall concept right now on linux appliances. You can install an older FW for the phones you have and change the device defaults to use it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 10/26/2009 - 08:04
  • Cisco Employee,
  • Hall of Fame,
    2011
java
fjrubiobarcena Mon, 10/26/2009 - 08:09
Thanks for your help. When do I change the device defaults, before or after rebooting the ucm once I have installed the older device package?
Jaime Valencia Mon, 10/26/2009 - 08:18
  • Cisco Employee,
  • Hall of Fame,
    2011
1st of all, unless you install a device package to provide support for a new model there is no reason to reboot. That's explained in documentation.
What you need to do is install an older firmware, NOT a device package.
java
