Bytes in Output queue
Oct 26th, 2009
I would like to use EEM, preferable an applet to monitor the number of bytes in an output queue on an interface of a catalyst 6500. Has anyone done this that can provide guidence an/or is there a better way to do this.
Preferable I'd like to get an alarm when it reaches a specific limit. I'm not lookin for packets in the queue like what we get from show int, I'm looking for number of bytes.
Joe Clarke Mon, 10/26/2009 - 09:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no way to do with a simple interface applet. What are you using to get this data now? What version of IOS?
l600671 Mon, 10/26/2009 - 09:55
I currently do not track this information and have not been able to find a way to get it. I would like it for input as well as output queues. The switches I'm hopeful to monitor are 6500's with Sup32 and Sup720s.
Joe Clarke Mon, 10/26/2009 - 10:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I don't know any command off the top of my head which provides informations on queued bytes. There may be a MIB object which gives this information, but you will need to provide your IOS version.
l600671 Mon, 10/26/2009 - 10:46
Sorry, I meant to provide that. We are running 12.2(18)SXF.
Joe Clarke Mon, 10/26/2009 - 11:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
SXF what? What is the feature set?
