CHRIS CHARLEBOIS Mon, 10/26/2009 - 08:53
  • Silver, 250 points or more
I think it depends on what version you are running. On mine, which is 6.1, there is a toggle button just to the left of the "Call Control Up" or "Call Control Down" on the bottom status bar which I believe turns off the feature that you want to eliminate.
Jaime Valencia Mon, 10/26/2009 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    2011
On the bottom of the AC client there is a little button that controls whether AC will show in front of all other apps when a call comes in.
PLEASE search NetPro for answers before posting, this has been asked many times before (there are even some threads with the screenshot)
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Rob Huffman Mon, 10/26/2009 - 10:21
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Michael,
Here is another method to enable / disable "Pop to Top" on AC
**Note: To toggle the pop-to-top feature on and off, press Alt + P.
Hope this helps!
Rob
