accounting on guest anchor controller
Oct 26th, 2009
Hi all,
Is there any way of doing ip accounting on the guest anchor controller to see which IP/mac is generating the most "bytes" in a 1 minute interval for example ?
Kayle Miller Thu, 03/11/2010 - 09:35
     If you have WCS and a specific guest SSID this is being anchored you can use a WCS Report to get the information i believe you want.. Run the Busiest Client report and choose the SSID and then select customize to choose the other fields and then it will show you who is the busiest client.
Hope this helps.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
