UCCX 7.x SQL Backend
Ryan LaFountain Mon, 10/26/2009 - 10:03
  • Cisco Employee,
Unfortunately, the answer to both is no. This type of configuration will not be supported by TAC. The database components must be installed on the UCCX box with the provide MSSQL Media.
There will be support for all voice applications in VMWare in later versions, they are undergoing certification for VMWare in the development labs until then.
Ryan LaFountain Mon, 10/26/2009 - 11:36
  • Cisco Employee,
You are correct. CUCM is not currently supported in a VMWare environment. I believe they are going to certify all UC products in the lab first and then roll out support for them.
As far as Ops Manager, you will need to talk to someone in NMS but I don't believe it is currently supported.
