IPSec VPN client IP does not get distributed via EIGRP
Answered Question
Oct 26th, 2009
We are using an ASA for remote VPN access. It is running EIGRP and redistributes static routes. When an Anyconnect SSL client connects, the ASA creates a static route for that client and it gets redistributed via EIGRP. When a IPSec VPN client connects, the ASA creates a static route for that client but it does not get redisributed via EIGRP and hence that client can't reach anything. Why would it not distribute a static created by a IPSec client?
Correct Answer by Ivan Martinon about 7 years 2 months ago
Have you configured RRI on the dynamic crypto?
Overall Rating: 5 (1 ratings)
brianhill88 Fri, 10/30/2009 - 10:59
That was the missing piece. With RRI it works correctly now.
Thank you!
