Upgrade Path for CUCM 6.1.2 daylight savings issues
Oct 26th, 2009
Doing patches for a CUCM 6.1.2.1000-13 wondering if update 6.1.4.2190-3 will resolve the daylight savings issue for the legacy ip sets not updating their time with the new DST standards. Thank you
loganseth Tue, 10/27/2009 - 09:02
I believe the answer is Yes, it should work. My (vague) understanding is 6.1(4) should contain all fixes in 6.1(3) (which is listed in that link of versions that are fixed).
russelljohnston Tue, 10/27/2009 - 09:05
Thank you, that is what I suspected but was trying to clarify my understanding. Thank you for your help.
