VTP with no vlan1
Answered Question
Oct 26th, 2009
Can vtp function in a network where vlan1 has been shutdown?
Correct Answer by Jon Marshall about 7 years 5 months ago
Jason
You can shut down the vlan 1 L3 SVI (Switched Virtual Interface) and you can clear vlan 1 from all trunks but Cisco switches will still use vlan for most management traffic. I say most as DTP actually uses the native vlan which may or may not be vlan 1.
But CDP/PaGP/VTP all still use vlan 1 regardless of what you do on the switch. By shutting down vlan 1 interface and clearing off trunks you are effectively disabling vlan 1 from being used for end devices or to manage the switch but as i say this has no effect on the majority of Cisco management traffic.
Hence the reason VTP still works.
Jon
Overall Rating: 4 (3 ratings)
a.cruea1980 Mon, 10/26/2009 - 14:57
  • Bronze, 100 points or more
Yes.
I wish I could go farther into detail on this, but I'm not that great with VTP and it's options. I just know I have VLAN 1 shut down at home and VTP still works.
I do know, though, that you can change the interface it sends out it's updates over with the "vtp interface" command.
jason.henderson Mon, 10/26/2009 - 15:04
Cheers for that, i thought that it must still be able to work but i'm not sure how. Will need to look into it a bit more.
Jason.
Correct Answer
Jon Marshall Mon, 10/26/2009 - 15:35
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jason
Jon
