TimACOX33 Mon, 10/26/2009 - 15:28
If you're referring to 64-bit IPSEC client I believe the answer is no.
A. Cisco VPN Client Version 5 is available for 32-bit Windows Vista. There are no current plans to provide 64-bit support for the Cisco VPN Client but 64-bit support is available for the Cisco AnyConnect VPN Client. This client and release notes can be obtained from the Software Center
Phillip Remaker Fri, 02/19/2010 - 11:18
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
