SCCP IP Phone Firmware for 4.x and 7.x
Oct 26th, 2009
We are preparing for UCM upgrade from 4.1(3) to 7.1(3). Is it possible to load SCCP 8.1(2) load, so we don't have to upgrade the IP Phones during the upgrade process? 8.1(2) is supported in both UCM 4.1(3) and 7.1(3) but I am not sure if this will work or not.
Thanks!
Jaime Valencia Mon, 10/26/2009 - 18:59
  • Cisco Employee,
  • Hall of Fame,
    2011
If there is FW available for your CCM version that is also the latest on a linux appliance you can install it with no problem, the FW is exactly the same. They way you install it is what's different.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
skravens0929 Wed, 10/28/2009 - 06:20
Rashid,
We are also looking to upgrade from 4.1 to 7.1.3. Are you staging on new devices or upgrading the current production boxes?
