Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1929376members
1243802discussions
Community Activity
JSON Response from REST Client CVP 11.5
Hi Team, I am trying to make a REST call using Call studio REST Client to an endpoint.  However, in my json response, i get multiple values. Although, i could see all the responses in the log, my requirement is to utilize only 1 response. As per docu...
dmehta by Level 1
  • 11009 Views
  • 31 replies
  • 5 Helpful votes
Fix empty startup-config for C9200L
For Cisco WS-C9200L-24T-4G-E, a user tried to backup configuration from Web portal. But did wrongly that uploaded empty text file to the device.That is:Copy to devicetftpaaa.txt (created from local computer)startup-configupload to device.Now the star...
Pleox by Level 1
  • 136 Views
  • 6 replies
ASR9K: mibd_entity に関する traceback が出力される
2024年4月15日 (初版) TAC SR Collection主な問題 ASR9000 シリーズルータにおいて、6.8.2 へアップグレードした際や、SNMP walk および entitystate mib の情報を継続的に取得しようとした際に、mibd_entity プロセスから以下のような traceback が出力される場合があります。 RP/0/RSP1/CPU0:Jul 15 16:10:29.952 IST: mibd_entity[339]: %SYSDB-BAG-7-...
how to safely turn off cisco router/switch?
how to safely turn off cisco router/switch?is it just turn off the power switch at the back of router/switchor need to issue soem command in user EXEC mode /privileged mode to shut down the router/switch? explain please, thank you
wxpsaint98 by Level 1
  • 279000 Views
  • 7 replies
Redundancy Over VSAT Link
Hi, we have a WAN and VSAT connection to one of the site. WAN is primary and VSAT is secondary link.We have dedicated router for WAN and VSAT. VSAT link is connected to one of the LAN access switch.Could you please help me, what kind of configuration...
inhamit by Level 1
  • 234 Views
  • 9 replies
Nueva actulizacion de CCNA
Buenos dias, Buenas tardes, Buenas noches, Se avecina nueva actualizacion para los CCNA si estas estudiando para presentar el examen esta informacion te puede ser muy util.  https://learningnetwork.cisco.com/s/ccna-v1-1-exam-topics Como resumen:https...
Catalyst 9800 シリーズにおいて、17.9.4a にアップグレードした後、クライアントが接続できない問題
2024年4月25日 (初版) TAC SR Collection主な問題 Catalyst 9800 シリーズにおいて、17.9.4a にアップグレードした後、クライアントが接続できない問題が発生する場合がございます。具体的には EAPoL Key 4way Handshake において、AP が Message 3 (M3) を送信しないため、暗号化通信が成立しない状況が発生します。ただし、これが発生する頻度は非常に稀です。 原因 ソフトウェア不具合 CSCwi18057 9800 WLC:...
Catalyst 9130 にて特定の syslog が大量に出力される
2024年4月25日 (初版) TAC SR Collection主な問題 Catalyst 9130 にて以下のような syslog が大量に出力される場合があります。 [CLEANAIR] W0 Unsolicited xxxx Command Response, status = xxxx 原因 CSCwh49406 Excessive Cleanir Syslogs from 9130 AP解決策CSCwh49406 の修正バージョンにバージョンアップすることにより、この問題は発生しなく...
Catalyst 9800-80 において正常な場合にも関わらず負荷平均の警告が表示される問題
2024年4月25日 (初版) TAC SR Collection主な問題 Catalyst 9800-80 において正常な場合にも関わらず以下の負荷平均の警告が表示される問題が発生します。 --- %PLATFORM-4-ELEMENT_WARNING: Chassis 1 R0/0: smand: 1/RP/0: 5-Minute Load Average value 5.18 exceeds warning level 5.00. --- 原因 ソフトウェア不具合 CSCwd86288 L...
C9800 で誤った Jammer アラートが出る問題
2024年4月25日 (初版) TAC SR Collection主な問題 C9800 で実際には存在しないデバイスからのJammer (電波干渉源の一種) を検知しアラートが出ることがあります。以下のコマンドからそのアラートを確認することができます。show ap dot11 5ghz cleanair device type jamme 原因 ソフトウェア不具合:CSCwh88320 False Jammer Alert on 9800-40 解決策 誤検知となるため、自然復帰を待つか、CS...
C9800 で誤ってクライアント接続上限到達の通知が出る問題
2024年4月25日 (初版) TAC SR Collection主な問題 C9800 で実際にはクライアント接続上限には達していないにも関わらず、上限到達を知らせる次のような通知が出ることがあります。2023/11/03 10:35:03.834080850 {wncmgrd_R0-0}{2}: [threshold-warning-mgr] [18204]: (debug): Checking threshold crossing for max number of wireless cli...
