Uninstallation Procedure for LMS
Answered Question
I would like to uninstall LMS and install fresh now that I have had a little more experience with the setup.
Is a simple uninstall via Add/Remove Programs sufficient? Or is there a known cleansweep procedure I can follow? Or maybe I just bite the bit and...gulp...format the drive for the best results? Any advice? :)
Thanks in advance!
Correct Answer by Joe Clarke about 7 years 4 months ago
Usually, yes. Sometimes, if the installation was originally bad, a typically uninstall will not work. In that case, there is a utility called clean_system.exe available from TAC which will purge LMS from a server.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 10/26/2009 - 16:38
