How to add 52 and 53 raduis attributes
Oct 26th, 2009
please, I am configuring a 10000 and I need to add "Acct-Input-Gigawords" and "Acct-Output-Gigawords" in the accounting register. How can I configure that ?
Thanks in advance !
Cleber
Jatin Katyal Tue, 10/27/2009 - 05:35
The RADIUS Attribute 52 and 53 Gigaword Support feature introduces support for attribute 52 (Acct-Input-Gigawords) and attribute 53 (Acct-Output-Gigawords). Attribute 52 keeps track of the number of times that the Acct-Input-Octets counter has rolled over the 32-bit integer throughout the course of the provided service; attribute 53 keeps track
of the number of times the Acct-Output-Octets counter has rolled over the 32-bit integer throughout the delivery of service. Both attributes
can be present only in Accounting-Request records where the Acct-Status-Type is set to "Stop" or "Interim-Update." These attributes can be used to accurately account for and bill for usage.
This should be available in the release they are running. Cisco IOS Software, 10000 Software (C10K3-P11-M), Version 12.2(31)SB13, RELEASE SOFTWARE (fc1)
I see there is a command that needs to be on but should be on by default. aaa accounting gigaword.
You may refer the COMMAND REFERENCE GUIDE for more info:
http://www.cisco.com/en/US/docs/ios/12_3/security/command/reference/sec_a1g.html#wp1085560
IMPORTANT # USAGE GUIDELINES #
The AAA high-capacity counter process takes approximately 8 percent CPU memory for 24,000 (24 K) sessions running under steady state.
If you have entered the no form of this command to turn off the 64-bit counters and you want to re-enable them, you will need to enter the aaa accounting gigawords command. Also, once you have entered the no form of the command, it takes a reload of the router to actually disable the use of the 64-bit counters.
JK
Plz rate helpful posts-
