Joe Clarke Mon, 10/26/2009 - 21:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It depends on what kind of granularity you want. Both DFM and HUM can do availability polling. However, DFM defaults to four minute polling, and HUM defaults to five minute polling. HUM is probably going to be more of what you want as it can provide the availability report graphs.
greg.loria Tue, 10/27/2009 - 01:58
Thanks for the recommendations. Of the three possible ways, which method could generate an alarm or notification if ever a time out on the connection occurs?
Joe Clarke Tue, 10/27/2009 - 05:39
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
DFM is the application that does this (though HUM could do it as well). You can configure DFM to send email, trap, or syslog notifications when a number of fault conditions occur (including unresponsiveness).
yjdabear Tue, 10/27/2009 - 11:11
  • Gold, 750 points or more
In the case of IPM for IP SLA, there's an "Action Event Type" dropdown menu option (second screenshot in that document). One of the options is SNMP Trap. Further down on the same screen, you can find the "Timeout Settings" option.
