Can ping indside host from host in DMZ but not other way around.
sfanayei
What is a problem? Tanks a lot for ant help.
andrew.prince
Level 10
Level 10
Check your NAT and access-lists.
HTH>
I have'nt any nat configuration but I have static command. Please show me en sample configuration for Access-list and a appropriate static command. Tanks a lot
If the inside is higher security the you need a static or a nat 0 to work bidirectionally. Something to translate or identity translate the inside host.
For example if ur outside is x then you will need
- static (in,dmz) x x (if you don't want to translate him)
- static (in,dmz) y x (if you want x to look like y for the dmz)
If you are trnslating the dmz host that is not right.
Also make usre you have routes to reach the host you are trying to ping by reaching the ASA first.
Also check your ACLs.
I hope it helps.
PK
