Dynamic & Static VTI
Oct 27th, 2009
I connect 2 routers with static vti. I have also configured a dynamic vti on each router in order to allow some users to connect from their PCs remotely. The static vti is working fine. When a remote user try to connect with vpn client to the network the tunnel that connects the two routers is disconnected.
Is it possible to have static and dynamic vti on the same router?
I am attaching the CLI configuration of one of the routers. The second router has similar configuration.
Herbert Baerten Wed, 10/28/2009 - 11:55
  • Cisco Employee,
try this:
crypto isakmp profile IKE-PROFILE-2
match identity address n.n.n.n (address of the peer)
crypto ipsec profile PROF1
set transform-set ESP-AES-SHA
set isakmp profile IKE-PROFILE-1
crypto ipsec profile PROF2
set isakmp profile IKE-PROFILE-2
interface Tunnel0
tunnel protection ipsec profile PROF2
If there is still a problem, then get :
debug crypto isakmp
debug crypto ipsec
debug crypto socket
debug tunnel protection
Start the debugs before the problem occurs.
