SNMP Help
Answered Question
Please find a question and response I posted on the telephone netpro section. I now need a little help from you chaps in the infrastructure section.
My situation is this - I have a 2650XL VOIP router and need to monitor the DSP interfaces. Jo sent me details of a MIB that I need to complete my task.
We have Ciscoworks LMS3.0.1
I need to now how to install this mib onto my router and also I need to understand if Ciscoworks can be used to monitor the interface or do I need to do it from the command line?
Any help or guidance would be appreciated.
Rod
HI Netpro's
I need to figure out how many of our ports are being used daily on our ISDN PRI circuit. We have 25 channels active and my company I looking to add an additional 200 staff in the coming months. I need to determine if I have enough capactiy in the PRI.
Rod
Hi Rod,
try this document from Cisco.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00801abe59.shtml
Bye
Jo
Correct Answer by Joe Clarke about 7 years 4 months ago
HUM will be available in the downloaded LMS 3.0.1 update. You will not find it on the LMS 3.0 DVD.
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 10/27/2009 - 05:43
Do you have the Health and Utilization Monitor add-on installed? This would be the only application within LMS into which MIBs can be loaded, and which can do this kind of polling. If you do, you can go to Admin > Load MIB, and load the CISCO-POP-MGMT-MIB. However, you will first need to go through the IMPORTS clause at the top of that MIB, and load all required dependencies.
Correct Answer
Joe Clarke Tue, 10/27/2009 - 07:27
