MLP LFI virtual template
Oct 27th, 2009
I configured LFI and I am not sure what the interface virtual-template 101 ip address should be ?
CCO documents usually use a ip unnumbered ethernet for the virtual-template.
In this scenario, a LAN interface is not available.
The config below works though:
interface Serial0/0/1.1 point-to-point
bandwidth 384
ip address 10.10.111.1 255.255.255.0
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 201 ppp Virtual-Template101
class frts-384
interface Virtual-Template101
bandwidth 384
ip address 10.10.111.1 255.255.255.0 <-------------- what ip address should be configured here ?
ppp multilink
ppp multilink interleave
ppp multilink fragment delay 10
service-policy output hq
Any help appreciated.
Thank you.
Paul
Laurent Aubert Wed, 10/28/2009 - 18:20
Hi Paul,
You can use any IP address because it's a PPP link. The idea is just to activate the IP stack. We recommend to use the addresss of another interface so you don't have to use a new one. Usually a loopback works perfectly as this interface never get down.
Laurent.
