Can you change the Soft Buttons on 7965
Oct 23rd, 2009
We are using 7965 phones on a UC540. From the research I have done you can edit the soft buttons on the comamnd line of the router by changing the ephone template. Is this the only way to edit the buttons? We don't want to add or delete any buttons, just change the order they appear in?
Saurabh Verma Tue, 10/27/2009 - 05:43
  • Silver, 250 points or more
Yes, today this feature is not supported through CCA. We have it on the roadmap for future releases of CCA.
-Saurabh
farrshepherd Tue, 10/27/2009 - 06:35
Currently there is information on how to change the ephone template via the CLI on the web. Do you think there is a problem in doing this via the CLI now or could it cause problems since it is not being done in the CCA?
Saurabh Verma Tue, 10/27/2009 - 06:56
You can configure this in CLI, although there are a couple of things to watch out for:
a) UC 540 is supported by Small Business Support Center which is available for configurations through CCA. CLI configuration is outside the scope of their support.
b) The Softkey configuration is not too complicated, so following one of the documentation shouldn't be too tough. Current version of CCA only configures template 15 and 16, so I would recommend that you keep your configuration in template 11-14. This will keep a future release of CCA from overwriting your configuration.
Saurabh
farrshepherd Tue, 10/27/2009 - 07:00
Thanks, that is good advice. Regarding the templates, how are they differentiated? What is the difference between template 11 and template 16? How do I apply the new template I made to the phones after creating the new template? What article do you recommend?
