PLAR with delay of 6 seconds on FXS ports
Oct 27th, 2009
Hi there
Is this possible???
If I lift the analog phones connected to the FXS port on the VG224, I should be able to dail out to any number however if I jlift the phone and keep it off-hook for 6 seconds without dialing any number, then it should dial out to a particular number.
is it possible??
James Hawkins Tue, 10/27/2009 - 12:44
Please provide details of what system you are using (CallManager or CallManager Express), the version number and the protocol running on the gateway.
mohammed.naviwala Tue, 11/10/2009 - 10:59
Call manager 7.0
VG224 on SCCP.. i want is if i lift the handset on the analog phone i can dial the number but if i do not dial any number for 6 seconds then it should auto dial to the operator
