Valid frames, too large
Oct 27th, 2009
I ran a #show controllers ethernet-controller gi1/0/47 and noticed a large amount of valid frames, too large. This counter is actively incrementing. This is on a Cisco 3750G-48TS. Any ideas why this would be incrementing?
Transmit GigabitEthernet1/0/47 Receive
2602709159 Bytes 3406571803 Bytes
506380833 Unicast frames 1845219495 Unicast frames
168755 Multicast frames 82689595 Multicast frames
7782 Broadcast frames 16653903 Broadcast frames
0 Too old frames 1070926140 Unicast bytes
0 Deferred frames 1387623328 Multicast bytes
0 MTU exceeded frames 1775188696 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 3 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 2511413 Minimum size frames
0 8 collision frames 408322611 65 to 127 byte frames
0 9 collision frames 8506293 128 to 255 byte frames
0 10 collision frames 7761467 256 to 511 byte frames
0 11 collision frames 56189463 512 to 1023 byte frames
0 12 collision frames 73921614 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 475912 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 1387826047 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
568105 64 byte frames 0 Valid frames, too small
26821639 127 byte frames
19506439 255 byte frames 0 Too old frames
7915924 511 byte frames 0 Valid oversize frames
17330690 1023 byte frames 0 System FCS error frames
52054055 1518 byte frames 0 RxPortFifoFull drop frame
382360518 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
daniel.nocito Tue, 10/27/2009 - 07:24
I ran a wireshark trace on the traffic inbound to that port. I don't see any frames larger than 1514. This interface is part of an etherchannel. Both internfaces in the etherchannel have the same too large frames
lgijssel Tue, 10/27/2009 - 07:27
  • Red, 2250 points or more
How did you attach the wireshark monitor?
If you did this via a monitor port, you will not packets that are not allowed in.
It may also be that the monitor itself is not configured to use jumbo frames.
daniel.nocito Tue, 10/27/2009 - 07:34
This is a switch connect to our core. I configured a monitor port on the core. This should capture all traffic to the switch. I will check on the wireshark. I am gussing I have to configure the linux machine to accept jumbo frames too.
lgijssel Tue, 10/27/2009 - 07:39
The problem with your setup is that you will only see the traffic that's accepted by the port.
It will not help you in this case because the too-large frames are discarded on input.
daniel.nocito Tue, 10/27/2009 - 07:43
My setup is
CORE -> Problem Switch
I have the monitor port on our core switch. So I am capturing everything outbound on that port on the core to the problem switch. The inbound on the problem switch is where I am seeing the errors. So the core is forwarding these large frames to the problem switch. Sound right?
daniel.nocito Tue, 10/27/2009 - 07:56
I just noticed a port that seems to be sending the jumbo frames. Am I reading the counter correctly down bottom. The "Too large frames"? Does this counter mean this host is sending large frames?
250519269 Bytes
11087485 Unicast frames
27074494 Multicast frames
20667232 Broadcast frames
0 Too old frames
0 Deferred frames
0 Late collisions
3003994 64 byte frames
43867440 127 byte frames
2789208 255 byte frames
377680 511 byte frames
157135 1023 byte frames
199063 1518 byte frames
8434691 Too large frames
daniel.nocito Tue, 10/27/2009 - 08:47
If I have too large packets on transmit and recieve, does that mean it is forwarding the traffic and just keeping a counter?
Mohamed Sobair Tue, 10/27/2009 - 08:58
  • Gold, 750 points or more
There is exessive hosts sending broadcast requests .
what type of traffic is going through this port of the switch?
Mohamed
