NAC Profiler 2.18: Endpoint Profiles Missing
Oct 27th, 2009
  • Silver, 250 points or more
This is a licensed Nac Profiler which has no canned Endpoint Profiles included.
I go to Configuration--->Endpoint Profiles---> View/Edit Profile List
The message I see is "No Profiles Found"
Please clue me in on what I am missing.
This is from the install guide:
"Enabling Existing Endpoint Profiles
Cisco NAC Profiler ships with a number of predefined Endpoint Profiles that have been created and tested in field deployments. These Profiles can be re-used as-is if desired, or may be modified as the situation dictates. In addition, they serve as templates for creating new profiles as outlined later in this section, and illustrate how different rule types and varying levels of certainty can be used to accurately Profile devices.
To view the list of Endpoint Profiles that are currently available in the system configuration, navigate to the Configuration tab, and select Endpoint Profiles option from the global navigation menu in the far left hand pane, or select Endpoint Profiles from the leftmost column of the table on the main Configuration page. Select View/Edit Profile List to display the Endpoint Profiles currently saved in the system configuration."
Thanks.
