Ciscoworks 2.5.1 on VirtualMachine?
Oct 27th, 2009
Just a quick ? before I attempt an installation of Ciscoworks 2.5.1. Due to time constraints on acquiring new hardware I would like to install Ciscoworks 2.5.1 on a VM running Windows 2003 Server. Has anyone attempted installing this version of Ciscoworks on a VM? If so, have you run into any specific issues? Thanks people, any info would be much appreciated!!!
MikeSz.....
Joe Clarke Tue, 10/27/2009 - 07:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is not supported. If you need VMWare support, you will need to install LMS 3.0.1 or higher. Then you will be able to install LMS on VMWare ESX 3.x.
