Leo Laohoo Tue, 10/27/2009 - 14:10
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Check and make sure your fans are working using the command "sh env".
dpgoodfellow Wed, 10/28/2009 - 06:24
All fans are ok, The fan is running high but that will be due over temp alarm. The inlet & chassis temps are okay, so not sure if this a bug in the IOS or a faulty sensor.
This has occurred on two routers in different locations with the same IOS both occurred shortly after a reload and recording the same 127c temp.
