capture on firewall
Answered Question
Oct 27th, 2009
Does using capture on firewall cause disruption to traffic flow , similar to what is expected/possible by debug.
Would it be advisable to run capture with all traffic flowing across.
Thanks.
Correct Answer by Collin Clark about 7 years 7 months ago
You should use a restrictive ACL to limit that issue. The resource utilization is determined by the amount of traffic hitting the capture ACL.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Tue, 10/27/2009 - 07:56
  • Purple, 4500 points or more
