Kill Tcl process !
Oct 27th, 2009
Hi all. I ran below script on my router for some testing purpose
foreach address {
10.1.1.1
10.1.1.2
10.1.1.3
10.1.1.254
} { ping $address re 2
As you can see this will ping the entire subnet. But after executing it, is there any way to kill this process ? any way of terminating it ?
Kindly guide me
Joe Clarke Tue, 10/27/2009 - 07:32
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can try either Control+^ then x or Control+C. Depending on the version of IOS, one of those should work.
illusion_rox Wed, 10/28/2009 - 01:57
Dear Sir, its not working, my IOS is 12.4(20)T. router is 2801. I tried all the combinations
ctrl + c
ctrl + z
ctrl + shift + 6
None is working. Can you tell me how to terminate it ?
Thanks in advance
Joe Clarke Wed, 10/28/2009 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
After cntrl+shift+6, did you type 'x'? If that's not working, try clearing the vty line on which the Tcl script is running.
