Cisco Catalyst 3750E web managment issue
Oct 27th, 2009
Hi all
Actually this is not a critical issues but my customer is asking for it. Web management (HTTP or HTTPS) is not working for some of the switches on the site. I noticed that three switches which I upgraded are the only ones facing the issues. I Upgraded it using the .bin file I downloaded from another switch.
Any Ideas
Reza Sharifi Tue, 10/27/2009 - 08:20
  • Cisco Designated VIP,
    2017 LAN
Hi Rami,
Can you give us a "sh ver | i bin" of one of the 3 switches?
Are they all 3750Es and have the same image
Reza
rami.saber Tue, 10/27/2009 - 10:12
Actually I dont have access now but all switches appear to have the same image which is c3750-universalk9-mz.122-44.SE2.bin
Lucien Avramov Tue, 10/27/2009 - 10:14
  • Red, 2250 points or more
Make sure you enable ip http server.
Then, to have the fancy web interface, you actually need to install the image with the .tar (that includes the .bin file for the catOS and the web part).
iyde Wed, 10/28/2009 - 03:21
  • Silver, 250 points or more
Hi.
Use the archive download-sw command to upgrade and use the .tar file, as mentioned, to make sure that the HTML files needed for web management are current with the binary image of the switch.
glen.grant Wed, 10/28/2009 - 16:21
  • Purple, 4500 points or more
Yup you need to load a .tar image as the tar image contains all the html files for the gui interface , the .bin does not and is generally used for CLI use only.
