Cisco CSC Web Filtering and Citrix\Ts users
Oct 27th, 2009
Hello we need to buy a cisco CSC module for cisco ASA, and we're using Citrix Presentation server and Terminal Server Users, is CSC capable of ahtentitcate transparent the users in citrix (x users are using same IP)?, the CSC uses ntlm for this?, thanks for all.
Panos Kampanakis Tue, 10/27/2009 - 15:41
  • Cisco Employee,
No, NTLM is not supported for authentication on the CSC.
CSC 6.3 integrated LDAP integration and different group policies.
But what you are trying to achieve cannot be done on the CSC.
I hope it helps.
PK
alig.norbert Sat, 10/27/2012 - 14:37
Hi there,
I suppose CSC 6.6 can still not support multiple IP/user mapping, right?
Man, fortigate can handle that stuff since years.....
Greets,
Norbert
Julio Carvajal Sat, 10/27/2012 - 14:42
  • Purple, 4500 points or more
No, as I already answered on the other question
Yes, it will be a problem as the AD agent will need to log every single time a user logs into a PC, then it will create a map ( username to Ip) In this case that will be the problem as all of them will have the same one."
