MOH not working.... Help required.
Answered Question
Oct 27th, 2009
MOH is not working when I place a call on hold and also during transfers. Checked in the Media Resources and the config seems to be working fine. Is there anywhere that I need to check apart from Media Resources. I have a Call Manager 6.1(2) system.
Correct Answer by James Hawkins about 7 years 7 months ago
Also if you have configured MoH to use multicast make sure the network is set up to support multicast traffic.
Also check your MRG's and MRGL's.
Overall Rating: 4 (1 ratings)
Guilherme Henri... Tue, 10/27/2009 - 10:53
  • Events Top Contributors,
    External, 2014
What is the call flow ? internal to pstn ? site to site ? MOH server's are registered ?
Do you hear a fast beep or deadly silence?
Never work or suddenly stopped working?
Correct Answer
James Hawkins Tue, 10/27/2009 - 12:26
  • Blue, 1500 points or more
sandeepontop Tue, 10/27/2009 - 21:29
Thanks guys for the info.. I restarted the MOH Servers and the issue was resolved. Restarting did the trick. Once again thanks for your timely help !!!
