ACS v4.2: Administration of ACS Internal Database
Oct 27th, 2009
we're using ACS v4.2 for MAB and vlan-assignment. We imported the user's (mac-addresses) to the internal database via "CSUtil". The solution is working very well, the process for adding new mac-addresses is running . The process for deleting „old“ mac-addresses isn't ideal, we need to optimize the handling of "deathly mac-addresses".
My question:
Is it possible to block and delete mac-addresses by "last login time"? For example mac-address 001e8c3b0c09wasn't connected for 60 days, the pc or notebook is replaced already and the entry in the database has to be deleted.
Any idea?
Thanks in advance and kind regards
Matthias
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Tue, 10/27/2009 - 10:52
Hi Matthias,
This feature is not possible with ACS. What you can try is to use extraxi software, from extraxi.com
You can integrate it with ACS and get all kind of customized reports, eg - when was the specific last connected...
most active user etc etc.
Here is the url http://extraxi.com/aaa-reports.htm
You can contact " Darpotter " one of the top netpros on aaa forum. He is with Extraxi and should be able to guide you further.
~JG
Do rate helpful posts
