how to enable VPN between these router and allow through PIX?
Oct 27th, 2009
Hi All,
Site I : T1
Router Cisco 1721
Firewall CISCO PIX 506e
Site II : T1
Cisco 1721
Firewall PIX506e
Site III: Bonded T1
Router :CISCO 12651
Firewall: Cisco PIX 515r
Thank you,
Siva
Overall Rating: 5 (1 ratings)
Laurent Aubert Wed, 10/28/2009 - 18:33
  • Cisco Employee,
Hi Siva,
If you want to build the IPSec tunnels from your routers and not from the FW, you need NAT-T feature. Also your FW should allow UDP on port 4500 from the outside in addition to allow it from the inside.
It would be easier to build your tunnels between the FW
The following link gives you plenty of examples:
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
Laurent.
