DFM Card Errors
Oct 27th, 2009
Hi Everyone, In LMS 3.2 DFM. I have a 3845 Router that is reporting CARD errors. The cards it is referencing dont exist on the switch as far as I can see. Is there someway I can tell what the real problem is or if I even should be monitoring these cards See attached screen shot. Notice the cards that are labeled CRITICAL in the status. Thanks.
Joe Clarke Tue, 10/27/2009 - 11:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I believe you are seeing a known device bug. Post the show ver from this router.
downeast75 Wed, 10/28/2009 - 05:41
Hi JClarke, we are experiencing this issue with 6 devices, attached is the list of versions from each device. Can you point me to the correct patch for the devices? Thanks for the help - JOHN
Joe Clarke Wed, 10/28/2009 - 17:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is CSCsj58422. If you upgrade these devices to 12.4(20)T or higher, the problem should go away.
