SSH in 2950 Model
Hi all,
Anyone help on this. Actually i am having 2950 switch. Now i login through telnet but as per the company standard i have to login through ssh. Is there any possible to enable the SSH in 2950. Any IOS supporting this operation.
flash:/c2950-i6q4l2-mz.121-19.EA1c.bin
Any advacned IOS is there to enable the ssh.
Kindly let me know.
Thanks in advance
Gopinath.
Overall Rating: 5 (2 ratings)
Lucien Avramov Tue, 10/27/2009 - 11:52
  • Red, 2250 points or more
The 2950 Enhanced Image supported SSHv2 starting 12.1(19)EA1 and the 2950 Standard Image started supporting SSHv2 starting 12.1(22)EA2.
I suggest you get the latest possible image, so you have the most bug fixes.
John Katsoulas Thu, 05/02/2013 - 09:38
Hello Lucien.
Re the 2 attached pictures. I read you are refering gopi to SW c2950-i6k2l2q4-mz.121-22.EA13.bin
Can I assume that the manual is wrong or is there a bug in the ios my switch is using?
cmarva Thu, 05/02/2013 - 10:08
John,
it does not appear that you are running the crypto version. There is is a k designator in the image name.
your sw is c2950-i6q4l2, and Lucien recommended c2950-i6k2l2q4 (notice the k2 in the filename). Other platforms will usually have k9 in the filename, or the ASAs usually have k8. - chris
glen.grant Thu, 05/02/2013 - 10:46
  • Purple, 4500 points or more
cmarva is correct , you do not have the correct IOS .  You will need
c2950-i6k2l2q4-mz.121-22.EA14.bin
John Katsoulas Sun, 05/05/2013 - 23:40
Thank you very much. I have already performed the update and everything is OK.
However, as a an improvement proposal, there should a little bit more clarity on Cisco manuals. Manual states v19, regardless of k requirement and the actual SW that can do the job is v22 with k attribute.
