Upgrade Packet Downloading Fails
Oct 27th, 2009
I'm attempting to download the regular 6.0.3 package through the web interface from the Cisco.com site. I had begun this process before, but MARS restarted before it could finish downloading. As a result, the package did not finish. Now, whenever I try to download the package, it tells me:
Attempted to download csmars-6.0.3.3188.zip failed because the file is already being downloaded.
Is there any way I can delete the old package and restart the download? Unfortunately, it does not show up in the web interface so I can't do it that way.
Thanks for any help!
Overall Rating: 5 (3 ratings)
Farrukh Haroon Tue, 10/27/2009 - 13:29
  • Red, 2250 points or more
The new java card did the same for me, so I just logged in from another CCO account and downloaded the required file.
I know that this is a pretty absurd suggestion, but it works :)
Farrukh
natehausrath Wed, 10/28/2009 - 07:20
Unfortunately this did not work for me. Is there a way to see and remove downloaded files via the console or anything?
yessercco Wed, 10/28/2009 - 07:54
You could try cycling the MARS services if possible, maybe this could help
natehausrath Wed, 10/28/2009 - 08:28
Good suggestion, but unfortunately this didn't work either. I'm guessing there isn't an easy way to do this other than going into expert mode, which I haven't had to do before.
natehausrath Wed, 10/28/2009 - 12:28
There was an easy way! It turns out that by running pnupgrade from the command line and pointing it to an FTP or HTTP server will work. Problem solved!
pmccubbin Thu, 10/29/2009 - 06:24
  • Silver, 250 points or more
Nathaniel,
Thanks for following up and posting the solution to your problem. A "5" from NYC.
Best,
Paul
