TED show crypto isakmp sa strange output
Oct 27th, 2009
i configured site-to-site vpn using TED betwen branches & HQ , when i access the branch the router & make show crypto isakmp sa , i find the following strange output:
Branch#sh cry is sa
dst src state conn-id slot status
10.20.112.1 10.26.50.254 QM_IDLE 2 0 ACTIVE
10.20.100.220 10.26.10.200 PEER_DISCOVERY 0 0 ACTIVE
10.20.100.220 10.26.10.200 MM_NO_STATE 0 0 ACTIVE (deleted)
10.20.100.221 10.26.10.250 PEER_DISCOVERY 0 0 ACTIVE
10.20.100.221 10.26.10.250 MM_NO_STATE 0 0 ACTIVE (deleted)
10.20.100.15 10.26.10.230 PEER_DISCOVERY 0 0 ACTIVE
10.20.100.15 10.26.10.230 MM_NO_STATE 0 0 ACTIVE (deleted)
the branch vpn configuration is :
crypto isakmp policy 10
authentication pre-share
crypto isakmp key ****** address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set my-transform esp-3des esp-md5-hmac
crypto dynamic-map dyn-map 10
set transform-set my-transform
match address VPN-Traffic
crypto map vpn local-address Loopback1
crypto map vpn 10 ipsec-isakmp dynamic dyn-map discover
interface Loopback1
ip address 10.26.50.254 255.255.255.0
interface Serial0/0/0.1 point-to-point
ip address 192.168.10.50 255.255.255.252
ip access-group TUB out
frame-relay interface-dlci 16
crypto map vpn
interface Serial0/0/1.1 point-to-point
ip address 192.168.20.50 255.255.255.252
frame-relay interface-dlci 50
crypto map vpn
ip access-list extended VPN-Traffic
permit ip 10.26.10.0 0.0.0.255 10.20.100.0 0.0.0.255
permit ip 10.26.10.0 0.0.0.255 10.20.200.0 0.0.0.255
permit ip 10.26.10.0 0.0.0.255 10.20.150.0 0.0.0.255
permit ip 10.26.10.0 0.0.0.255 10.20.30.0 0.0.0.255
it should give me only :
branch#sh cry is sa
so is this a bug in the branch router IOS
version used is :
c2800nm-advipservicesk9-mz.124-3g.bin
