Terminal Services
Oct 27th, 2009
Trying to move a client over to the UC520 from a SonicWall and had a few problems today wiht it.
Customer states they are running terminal services.  There data company stated that this was fromt he SonicWall and we need to make these changes for items to work.
CAMERAS 8000 12000 TCP
CAMERAS1 8000 12000 UDP
SR Camera 7000 7000 UDP
SR Camera1 7000 7000 TCP
second RDP 4489 4489 TCP
RDP = 3389 TCP
Send E-Mail (SMTP) = 25 TCP
1 Through 16 is for their spam filtering at AppRiver
1              69.20.58.226 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
2              69.20.68.133 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
3              207.97.224.142 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
4              207.97.229.125 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
5              207.97.230.34 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
6              207.97.230.54 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
7              207.97.242.51 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
8              92.52.89.74 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
9              74.205.4.52 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
10           72.32.252.16 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
11           72.32.253.10 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
12           72.32.252.97 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
13           69.20.60.122 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
14           69.20.58.234 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
15           212.100.247.159 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
16           212.100.247.15 - 212.100.247.159 (WAN) 192.168.1.10 (LAN) Send E-Mail (SMTP) Allow
17           LAN 192.168.1.1 (LAN) HTTPS Management Allow
18           LAN 192.168.1.1 (LAN) HTTP Management Allow
19           *(WAN) 192.168.1.10 (LAN) second RDP Allow
20           *(WAN) 192.168.1.10 (LAN) Retrieve E-Mail (POP3) Allow
21           *(WAN) 192.168.1.10 (LAN) PC Anywhere Allow
22           *(WAN) 192.168.1.25 (LAN) CAMERAS1 Allow
23           *(WAN) 192.168.1.1 (LAN) Key Exchange (IKE) Allow
24           192.168.1.1 (LAN) * Key Exchange (IKE) Allow
25           *(WAN) 192.168.1.10 (LAN) Web (HTTP) Allow
26           *(WAN) 192.168.1.11 (LAN) Terminal Services Allow
27           *(WAN) 192.168.1.12 (LAN) SR Camera Allow
28           *(WAN) 192.168.1.12 (LAN) SR Camera1 Allow
29           *(WAN) 192.168.1.12 (LAN) Any Allow
Any idea were we would make these changes.  As I can see from the NAT tab in CCA, I only can select certain features, like web server, email server, etc.
Any thought or referecnes would be greatly appreciated.
Joe
Saurabh Verma Thu, 10/29/2009 - 05:54
  • Silver, 250 points or more
Hi Joe,
This feature is currently not supported through CCA. You will need to use CLI for allowing the desired IP addresses to be excluded from firewall blocking. There is an access-list on the WAN interface, modify the access-list to allow these IP addresses.
-Saurabh
7bridgesol Thu, 10/29/2009 - 08:01
two things:
interface fast Ethernet 0/0 states below ip access group 105 in.  Would I then be adding a cli command of access-list 105 permit ip (and list each IP for spam filtering)
Second, I am trying to add thru the NAT tab in CCA a other TCP to 192.168.1.11 for inside and outside port 3389 for terminal service.
I get this error when hitting apply  com.cisco.cpnm.features.defn.security.vpn.sslvpn.SslVpnData
How can I add the interanl and outside ports for the few setting above via cli or what can I do about the error.
Steven Smith Thu, 10/29/2009 - 08:54
  • Gold, 750 points or more
Have you made changes via CLI already?  That could be a problem.
If not, could you post your cca logs and a config?  Remember to remove the passwords.
7bridgesol Thu, 10/29/2009 - 09:48
sort of but who knows now.  I am uploading the last running good config.  I have made some changes in per CCA, NAT is not enabled on any interface.
the config here allowed us on the Internet but could not run terminal services via port 3389 to 192.168.11 and no email was coming thru.
I think I have to do a reload to get this config back up.
