service object-group
Oct 27th, 2009
I want to replace the following:
access-list 101 permit tcp host 192.168.50.100 eq www any
access-list 101 permit tcp host 192.168.50.100 eq 443 any
I figured I could just create a service group and create the ACL.
conf t
object-group service WebServices
tcp www
tcp 443
ip access-list extended 188
permit tcp host 192.168.50.100 eq WebServices ( <--problem here)
'permit tcp host 192.168.50.100 eq ?' doesn't give me the option of adding a service object group. 'permit tcp host 192.168.50.100 ?' only allows network object groups. And applying the service object group at 'permit ?' doesn't make sense (don't know if it's source or destination ports). When I look here: http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_object_group_acl_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1113487 It says I should be able to put a service object group directly behind the network object group. But this isn't the case for me. 'permit tcp object-group WebServers ?' only allows network object groups. I'm running Version 12.4(24)T1 on a 7206. Anyone know how to use this properly? TIA.
Collin Clark Tue, 10/27/2009 - 14:18
  • Purple, 4500 points or more
Try removing the TCP keyword. Here's the line that worked for me.
access-list 188 permit object-group WebServices host 192.168.50.100 any
thotsaphon Tue, 10/27/2009 - 15:35
  • Gold, 750 points or more
Steven,
Based on the document you provided. You want the service object group to be applied on the source addresses. Object group won't work the way you want. It's because of the service object group can be only applied on the destination. Why? If you read that document clearly. It says that the service object group is only to replace the protocol keyword in ACE. You can't use the service object group after the eq keyword. (grin)
The network object group is simply used as Src or Dest IP addresses in ACE.
The example provided by Collin is the correct syntax for permiting host 192.168.50.100 to go to any IP address with WebServices. It's something like this "permit ip host 192.168.50.100 any eq [www&443]"
HTH,
Toshi
snickered Tue, 10/27/2009 - 17:08
It still doesn't make sense to me. I want to understand why I can't issue the command 'permit tcp object-group my_network_object_group object-group
my_service_object_group any' like in the document. After the network object group I'm only allowed to issue another network object group. The syntax supplied in the document looks like I can use it the way I need to but it simply doesn't work. Here's what I see:
Router(config-ext-nacl)#permit tcp object-group WebServers ?
A.B.C.D Destination address
any Any destination host
eq Match only packets on a given port number
gt Match only packets with a greater port number
host A single destination host
lt Match only packets with a lower port number
neq Match only packets not on a given port number
object-group Destination network object group
range Match only packets in the range of port numbers
The document shows the next statement as 'object-group my_service_object_group' which would imply a service object group (not network object group). What gives?
