2960 24TC-S Lan Lite Software Upgrade.
Oct 27th, 2009
I have a 2960 24TC-S catalyst switch with current lan lite software which only supports 64 vlans. I have to install it to a company which needs at least 255 vlans.
Is it possible for this model to be upgraded to an IOS with more vlans like lanbase or ipbase?
Thanks you.
MAC
jbrenesj Tue, 10/27/2009 - 19:05
  • Silver, 250 points or more
Unfortunately the LAN-Lite 2960 cannot be upgraded to LAN-Base.
It's a limitation of the device itself.
Cisco introduced the Cisco Catalyst(r) 2960 Series Switches with LAN
Lite Software for entry-level small branch offices and wiring closets. These
three Cisco Catalyst 2960 Switches with LAN Lite Cisco IOS(r) Software simplify
the migration from nonintelligent hubs and unmanaged switches to a fully
scalable managed network. The LAN Lite Cisco IOS Software provides entry-level
security, quality of service (QoS), and availability capabilities while
lowering the network total cost of ownership.
