static assignment of LWAPPs for management
Oct 27th, 2009
I need to monitor my 200 plus LWAPPs that are connected to WISM controllers. What does/how does the static option on the general screen of the AP setup on the WISM controller, will it make the address it learned via DHCP static at net reboot or will I have to enter a static address to make this work.
weterry Tue, 10/27/2009 - 22:40
I'm pretty sure that if you check the box, it should auto-populate with the current dhcp configuration. If that is the case, then when you apply this it should effectively assigned that dhcp address as the static ip address.
