10-27-2009 08:40 PM
I have attached a screenshot of my Campus Topology View since the upgrade. I am able to see the green icons on 1 of 3 clients. My 2 PCs have boxed outlined as placeholders instead. Where do I start?
I uninstalled all Java versions from my PC right away thinking who knows...I installed the CM prompted version with jacorb packages, but it didn't change the result.
I attached a screen shot for witness. Also note the Zoom icons at the top left are missing as well.
Solved! Go to Solution.
10-27-2009 09:08 PM
Delete the Java cache from the Java Plug-in control panel. Then restart Campus. If the problem persists, post the output of the Java Web Start console.
10-27-2009 09:08 PM
